Ordinate dimensions defaulting to 'chained'
I have a drawing template which I've been using with which I can create ordinate dimensions which do not come up as chained. I've recently switched to a new drawing template created by someone else in the office. With this new drawing template, every ordinate dimension is automatically drawn as chained. This requires me to manually de-select the 'Chain Dimension' check box on every single ordinate dimension I create. I can find no option or setting anywhere, in the template or elsewhere, which allows me to toggle the chain dimension option. I've tried re-saving the template with ordinate dimensions drawn in and unchained, also without success. The individual who created the new template is also at a loss to explain this behaviour.
I could go with the brute force method and redraw the template using my old template as the base, but would prefer to know what setting or parameter I'm missing.
RE: Ordinate dimensions defaulting to 'chained'
