SW 07 and 08 on same PC
Has anyone noticed any issues running SWorks 2007 and 2008 on the same workstation?
RE: SW 07 and 08 on same PC
Might need to tell SW to change the default directory where it stores templates, Toolbox stuff, etc.--it's the non-Program-Files directory and I think you can specify this during install to prevent the overlap problems with toolbars and the like.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
No problems here just have to change your SW install directory. One thing you have to understand is that if you have TB you have to decide if you want to overwrite your old version of TB. If you do then your old version will not be able to use TB anymore.
I had SW05 to 08, but now just have 06 to 08. No problems here.
If your toolbars are giving you errors like Toolbar inconsistence, then you need to look that up in KB there is fix for that, but the TB locations etc... are saved individually at the reg level. Only problem I know there is with TB other then above is if you use Vista OS.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
