Errors in drawing sheet format.
Has anyone come across a setting which needs to be turned on/off in order to get rid of an error message?
Basically if there is no description/material etc in the model, which would otherwise be linked in the sheet format there is an error message coming in. See the attached jpeg.
RE: Errors in drawing sheet format.
