Lovelock CO2 reduction 10metre OD 200m long tubes
James Lovelock has proposed the construction of massive ocean pipes "100 to 200 metres long, 10 metres in diameter and with a one-way flap valve at the lower end for pumping by wave movement" to pump water up from below the thermocline to "fertilize algae in the surface waters and encourage them to bloom.
The idea is theoretical, and the authors note that it "may fail, perhaps on engineering or economic grounds".
My prelim calc indicate that steel & relevant buoy would be far too heavy so it would have to be plastic/GRP. But out in the big bad offshore world they would have to be pretty meaty with a large t/D ratio. Anyone know a manufacturer of big GRP pipes?
I suspect the idea is untenable but as an engineer I want to know how unfeasible it is.
cheers
cheers
RE: Lovelock CO2 reduction 10metre OD 200m long tubes
Narendranath R
Pipeline engineering is made easy with state of the art computer software, visit www.narendranath.itgo.com.
