Autocad 2002 Menu Load Failure
I accidently started an un-install on Autocad 2002. I canceled and did a re-install of Autocad 2002 and now when I start Autocad 2002 I get the following message:
Menu Load Failed: File Not Found:edw.(mnu/mns/mnc)
What is that and how do I correct it?
RE: Autocad 2002 Menu Load Failure
I typed the MENUUNLOAD command and that menu was not in the list to remove... In fact only 2 menus were listed, both ACAD menus... So I don't know where or what that "edw" thing is... I re-named the file edw.mnu and the problem seems to have gone away for now...
Ahh, maybe you have Solid Works installed?
Lothar
ADT 2004
I un-installed Autocad 2002 and "up-graded" to Autocad 2004... No problems with a fresh install of ACAD 2004... No, I do not have Solid Works installed...
