laser etching 4130 tube
dunno if im in the right section , but does anyone know if there is some sort of cnc laser that can etch a really intricate design (such as a cartoon) to the complete outside diameter of 4130 some chromoly tubing , and if so do you think that it will comprise the structural integrity of the tubing , thanks
daniel
RE: laser etching 4130 tube
YES, intricate patterns can be done.  Check with laser marker companies (suppliers or job shops) to do prototypes & samples.
Marking will discolor the material to make graphics & text readable.  Quality will vary.  Etching requires more laser power, disrupts the surface of the material.  It will compromise structural integrity, but by how much?  You must determine this.
TygerDawg
Blue Technik LLC
Advanced Robotics & Automation Engineering
www.bluetechnik.com
