File Structure of the SAFE's .F2K file
Who can tell me the file structure of the SAFE's .F2K file so that I can use a text editor to edit the .F2K file instead of using the interactive input of the SAFE program to slowly input the loadings one by one !!
RE: File Structure of the SAFE's .F2K file
Patrick
Its structure is as simple as ETABS / STAAD.
You can look at the input file, which have sub headings with $ symbol i suppose.
Its pretty easy, you may need to follow the exact format, i.e. "
