Thermal properties-Conductive Epoxies
All,
I am looking for complete thermal properties for electrically conductive epoxies. These properties are hard to come by (atleast from what i have seen online) and so I will take what I get and not worry too much about minor changes in components.
Thanks in advance....
RE: Thermal properties-Conductive Epoxies
Heckler![[americanflag] americanflag](https://www.tipmaster.com/images/americanflag.gif)
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
o
_`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
Unfortunately I couldnt find what I was looking for in 3M. TC-2707 is thermally conductive (electrically insulative). I need electrically conductive.
(1) Sometimes, rarely, you can get them to do some mechanical tests for you. Sometimes they have the data hidden away and you just need to ask for it.
(2) Otherwise you have to do them yourself (i.e. send cured test coupons to a lab). By the way, don't be surprised if the materials aren't linearly elastic.
Then if 1 or 2 doesn't happen:
(3) Buy the material, apply it to your application, and test it. This can be costly if it fails, but a properly design test can give you a good basis to base and qualify future designs off of. You may be able to test it by similarity rather than using the actual 'expensive' components.
