moving mass
moving mass
Hi all,
what is in your opoinion the best way to model a mass moving on a line meshed with beam elements?
thanks in advance,
andrea
thanks in advance,
andrea
Andrea Mordini, Civil Engineer, Ph.D.
http://www.andreamordini.com
RE: moving mass
Now, depending on what you're doing, you may need to divide that line into many beam segments in order to get the appropriate resolution.
What is the real intent of your analysis? If you're just using the mass to apply inertial loads to your beam, you're better off using tabular loading. You should know the mass, and the acceleration, so you know the force. Define a table that relates your force magnitude to time/position and go from their.
Hope this helps,
Doug
RE: moving mass
Coffee hasn't kicked in yet.
RE: moving mass
thanks for your response.
This could be a good idea, but what about if I have more than one moving mass and if the mass values are different?
For example one train passing on a bridge with the first wagon heavier than the second...
I tried to define all the masses and to connect them with the nodes on the bridge by using the CP or CE command but there's a numerical problem and I don't know why...
andrea
RE: moving mass
RE: moving mass
I define the masses I need and I put some constraints on them. Then, when the masses enter the bridge, I release the constraint and I create a CP between the first mass and the first node on the bridge. In the subsequent step, I delete the CP and I create a new one with the next node on the bridge.
The CP commands can be used in the SOLU processor.
Hope this helps the next one solving the same problem.
andrea
