Problem saving and reusing Note Favorite.
I'm saving a Note to the Design Library. The Note works fine with the exception of the last line of the Note. The last part of my Note is an inserted geometric tolerance. I get an error that says: #error broken link. What am I doing to cause this error?
RE: Problem saving and reusing Note Favorite.
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
If you look at the file types in the Annotations section of the Design Library, each type of favourite has its own extension;
.sldgtolfvt = geometric tolerance
.sldsffvt = surface finish
.sldweldfvt = weld
.sldblk = regular block comprising geometry and text
.sldnotefvt = regular note comprising text only
Have you asked your VAR about this?
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
