Is it required that all reference parameters be external?
I am trying to create an assembly with a pin and a solid to remove that represents a C'bored hole subtracted from a solid block.
I want to be able to rotate the C'bore by what ever degrees I choose.
I have created a rotation line under construction geometry that is Angle/Normal to curve.
I then published this line and created a parameter.
Changing the number under parameters I can rotate the line however when I try to tie it to the C'bore rep I can't get it to rotate.
Am I going about this the right way?
Is it necessary to create this line as an external reference?
I am new to Catia.
[URL=http://imageshack.us][IMG]http://img223.imageshack.us/img223/8119/ejectorpinmachiningiq1.jpg[/IMG][/URL]
