Nozzle design for FRP tanks
For steel vessel we refer to WRC107, but there is nothing for FRP tanks.
I need to define allowable loads ( forces and moment ) acting on a nozzle.
I will appreciate any suggestion and help.
Manu thanks in advance.
RE: Nozzle design for FRP tanks
edemarcos (Structural)
User’s Guide to ASME Standards for Fiberglass Tanks and Vessel MTI Publication No. 50. RTP-1 and ASME Section X.
L S THILL
Thanks to all for helps, but codes give general rules, nothing like WRC107.
I believe to define allowable loads I shall perform a finite element analysis.
best regards
Option:
contat Richard Ay, at COADE
Piping Stress Analysis COADE CAESAR II:
Has a reference paper for FRP analysis.
Discussion Forum for CAESAR II. Moderator:  Richard Ay, Dave Diehl http://www.coade.com/support_discussion.asp
search for FRP analysis and WRC 107.
FE-Pipe - Nozzle Pro by Paulin Research Group www.paulin.com can be use for this type of analysis WRC107, for FRP tanks (forces and moment) acting on a nozzle.
CODEWARE Pressure Vessel Software COMPRESS www.codeware.com and or other vessel application change the material property FRP. run WRC-107, and for CODEWAREE COMPRESS FE-Nozzle.
or CONTACT Paulin Research Group: SUPPORT / CONSULT
support@paulin.com
MAILING ADDRESS
11211 Richmond Ave., Suite 109
Houston, TX  77082  U.S.A.
281.920.9775 v
281.920.9739 f
L S THILL
