field applied silver "plating" for bolted connections
I'm looking for field applied silver for bolted power connections.
Cool-Amp makes a powder, but I believe I've seen 2 or 3 part liquids used commercially
RE: field applied silver "plating" for bolted connections
What's the reason to look for such a field applied silver plating ?
Doing the plating during manufacturing will usually provide better results at less costs.
If you are looking to fix a problem, be sure that not other design or manufacturing flaw is involved
