Calculate Noise level and wearing of PCV
I want to calculate noise level and wearing of PCV with a nominal pipe dia of 2 in, valve size is 1 in and valve body is 0.375 in.
The process conditions are:
Pressure: 50Psig
Drop through valve: 15 psi
Flow: 310 lb/hr
Mol. Wt.: 57
Temp: 250 F
Please provide me the details to check this valve performance.
Thanks.
Pressure: 50Psig
Flow: 310 lb/hr
Mol. Wt.: 57
Temp: 250 F
Thanks.
RE: Calculate Noise level and wearing of PCV
If you can't figure it out after reading that, call back.
http://virtualpipeline.spaces.msn.com
