need help solidworks cutout
RE: need help solidworks cutout
It depends on what your intent is. If you don't want the cutout to go all the way through, select offset from plane/surface then choose a distance that starts the cut on the outside of the cylinder, then choose the depth.
You could also create a plane normal to the curve of the cylinder and cut from there.
There are always a multitude of ways to get to what you want in SolidWorks.
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Thanks for your reply,
Can you guide me step by step?
Open part/select extruded cut/select plane? (witch plane?  how?)
Because of the location of the origin in the part that i have open, any plane that I can select will lie in the center of my part.
In my picture you can see that the cutout is going from de surface (10mm deep)into the cilinder.
Please explain how,
Do I start in the editing part mode and use the extruded cut button? and sketch from there? Because I get a error telling me to select a plane I must doing something wrong!
Or do I use the sketch or 3D sketch mode?
Toolmaker
To offset a plane (for your needs):
select the plane that is parallel to the axis of the cylinder. Hold down the ctrl key and drag the plane. Set the distance to 1/2 the outer diameter.
To create an offset cut:
Create the sketch on the plane that is parallel to the axis. When the Cut-Extrude dialogue box pops up, select 'Offset' in the 'From' box, set the distance to 1/2 the outer diameter. Then select your cut depth as you normally would.
Beyond all this, have you gone through the tutorials and/or received any training? If not, you should. It will help you out a lot.
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
The tutorials in the SW help section should be your starting point. Some training from you VAR would be the next most useful step.
Here are some others which will be useful.
The tutorial section in http://eng-tips.com/faqs.cfm?fid=520
http://mkt.solidworks.com/emarketing_enu/start.swe?SWECmd=GotoView&SWEView=eMarketing+HTML+Smart+Script+Player+View&SWERF=1
http://www.solidworks.com/pages/products/swofficepro/SWOfficePremium_VideoVault.html
cheers
altnickee,
Has your company set you up for training? Can you go to your VAR for training?
Or are you learning from home?
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
JMirisola,
This was exactly what i needed to know!!
I am a Toolmaker in the conventional way, no CNC machine, but find cad/cam a good help to design parts before making an attempt to manufacture.
So a few years back I met a friend who was working with solid edge V16, when he got a newer version of SE, I got the opportunity to work with the old version.
In a small (conventional) toolmaker shop, there is just not enough income to invest in cad cam training, so I did the tutorials, bought a book, visit some forums and thought myself what I needed to do my work.
My friend has CNC machinery, and he fabricated some work I made up in solid edge successfully.
During my time working with solid edge I was searching the internet for tutorials and tips, and found many interesting topics about solidworks.
My friend however was moved to another country, so when I spoke him on the phone and told him about solidworks, he told me that he was already working with solidworks, and as soon as he was upgrading to a newer version, I can use his older version again.
Being familiar with solid edge and thinking that solidworks was almost the same made me forget to do all the tutorials and started immediately, resulting in my questions.
I have searched the help section and the tutorials but might have overseen the answers.
I have to tell you that I speak & read English but find it difficult to understand the more technical descriptions in the help section & some of the tutorials, with the result not able to finish the tutorial.
Sometimes I follow the tutorials step by step and still not able to finish, resulting in frustration, finding out later thru the forums, that I need to adjust my settings somewhere!!
Thanks to everybody for their effort to help me.
Greetings,
Toolmaker
If you are using someone else's software then you are committing piracy.  You really should purchase your own copy if you intend to continue using SolidWorks.
I am using one of his laptop (legal version) he has a few laptops for his employees, but if he needs it again,i have to get to get it myself in the near future.
toolmaker
altnicknee ...
A friendly FYI ... SolidWorks does not sell its software. It merely sells/leases a license to use the software, and licenses are transferred to newer versions when they are installed.
So although the version you are using may not be ripped-off (in the usual sense), the fact that its license is not current makes your use of it illegal. You would be wise to not advertise that you are using it. You should perhaps, also inform your friend.
cheers
clear!!
I have just contacted the distributor and they are going to sent me the latest trial version, and they have a training day coming up for which I am invited. after that I can see what is best in my situation.
Toolmaker
