Fabricating a tube for cold probe
I have a cold probe, cylindrical shape, 1.5" diameter 8" long. Side wall is corrugated. Major diameter 1.5" and minor diameter 1".
I need to insert it inside a tube and am soliciting your suggestion to maximize heat transfer between the cold probe and the tube. What material shall I use to fill the gap between the tube and the probe? it's going to be a permanent setup. No need to disassemble later. Thanks.
RE: Fabricating a tube for cold probe
TTFN
TTFN
