Open Part-Properties in Assembly
Hello, I'm bussy creating a way to insert some properties automaticly.
I've made a VB-plugin to update the Properties when a surface has changed. This is in a part.
But when a make an assembly and make the part Addaptive and press Update in the assembly, The Part resizes, but the property doesn't change. When I pres edit or open on the part, the Property updates.
Is there a way that the part will resized and the properties will be updated?
I've tried to edit the properties of the part in the assembly, but i don't know how to get to the properties of a part.
Can you help me with one of my questions?
