Repair of CRA Clad Pipeline
As anybody come across a repair method for a Subsea Corrosion Resistance Alloy [CRA] internal clad pipeline? Please describe your experience.
Rgds Naren
Narendranath R
Pipeline engineering is made easy with state of the art computer software, visit www.narendranath.itgo.com.
RE: Repair of CRA Clad Pipeline
This is for planning emergency repair spares. The pipeline could be damaged by anchor drops/pulls or due to corrosion failure at welds etc.
Narendranath R
BTW there are some versions (If not Oceaneering, I forget who makes them) with hydraulic actuated sealing and misalignment fittings, etc. usually for deeper water, easier to install with ROVs.
http://virtualpipeline.spaces.msn.com
Split sleeves and Mechanical connectors work well with carbon steel pipeline. Repairs for CRA clad pipeline needs to maintain corrosion resistant after repair.
Narendranath R
There should be approved weld and weld repair procedures debeloped at the time of project start-up. If the damage is corrosion failure at a weld then the weld repair procedure should be followed and hyperbaric welding may be necessary.
If its a section of pipeline which has suffered mechanical damage bad enough to require full replacement of the damaged section then have fabrcated a clad pup-piece of sufficient length to replace the damaged area. Then hyperbarically cut the latter and weld in place the pup-piece using the approved weld procedure.
Nigel Armstrong
Karachaganak Petroleum
Kazakhstan
narenr,
I thought you knew that and were looking for something suitable for an emergency repair.  Not to say that a claded repair clamp could not be developed.
Nigel,
The clamp system was designed as a more cost effective alternative to divers and hyperbaric welding, but if the water depth allows, why not?
