How to link a ug part into knowledge fusion program
how to link a ug part into knowledge fusion program.
 For example there are some solid bodies and few points lying in a part file. I want to generate a program so that it calculates the minimum distance from all the points to some of the solid bodies. I want to select the bodies from the gui when the program is run.
any help is highly appreciated.
