Need 2000kva Transformer
Does anyone know where I could get the  following transformer in Europe,
Model T 110
10.48Kv - 420V
2000KVA AN
3 ph dry type with natural cooling
50hz
Cast Resin transformer
I am not too familiar with transformers being from a mechanical backround but we have one down and causing a lot of problems so if anyone can help it would be much appreciated.
RE: Need 2000kva Transformer
Such a transformer is quite a standard type for industrial applications in Europe
If you need a quick replacement try http://www.helmke.de/uk/start.html
Thy might be able to provide such a transformer from stock.
