Threaded insert to fit umodified m5-0.8 tapped hole?
I have a tapped hole, m5-0.8 in a hardened steel member. I need to step down the size of this hole to ideally m4-0.7, but anything smaller than that could work. Are there any threaded inserts that can do this? The coil type all use a special tap which could not cut this hard steel.
Thank you
Thank you
RE: Threaded insert to fit umodified m5-0.8 tapped hole?
Don
Kansas City
http:/
Kevin
“It is a mathematical fact that fifty percent of all doctors graduate in the bottom half of their class." ~Author Unknown
"If two wrongs don't make a right, try three." ~Author Unknown
h
http://www.ezlok.com/TechnicalInfo/brochure.html#
Larry
