Equivalence to a High Frequency Start
In welding statinless with a GTAW procedure. Would a lift start be considered an equivalent to a high frequency start.
Thanks in Advance
RE: Equivalence to a High Frequency Start
Not the equivelant but it achieves the same end result. No arc strikes or broken tungsten stuck to the base metal.
The equipment I have used for lift start was much more foregiving when crawling through pipe racks and covered with sweat.
In many cases scratch start is used with a regular CC power source.
If your reference to "procedure" is an ASME Sec IX WPS. The arc initiation method is not controlled.
