CHANGING DIMENSION TEXT
I must have changed a preference somewhere which I'd like to change back. When I dimension a circle the dimension text appears as <MOD-DIA>8.000.... I'd like to get rid of the text in parenthesis and just have the number. I can delete the text by removing that text from the "dimension text" window in the dimension dialogue window... but it removes it only from that one instance. How to turn it off permenantly for every instance.
Thanks.
John
Thanks.
John
RE: CHANGING DIMENSION TEXT
Have you tried simply re-starting SW? Or rebooting?
thanks.
Not sure why, usually just exist out of solidworks & go back in. Not the best fix, but glad to know it's not just me.
