Piping Commodity Codes / Material Catalog
My company is setting up a new Piping Material Catalog for engineering and material management. Are there any generic databases out there (non vendor) that we can use instead of starting from scratch?
RE: Piping Commodity Codes / Material Catalog
http://virtualpipeline.spaces.msn.com
Also, Global Valve Cross-Reference eCatalog (GVCC)http://www.fiatech.org/projects/idim/gvcc.htm
Piping Engineering & Complementary Practices:
Engineering
Fabrication, Installation,
Testing & Examination
Procurement
Use of Piping Practices
PNCM0002 - Piping Material Specifications Line Class Index
This Practice provides a listing of the PIP Piping Material Specifications. PNCM0002 describes the basic characteristics of each PIP Material Specification. Each specification listed is described by pressure class, primary material, corrosion allowance, service type, and joint construction.
PNCM0002 - Piping Material Specification - Line Class Index
Click here for free download of this Practice
Date: 05-06 (Complete Revision) http://www.pip.org/downloads/PNCM0002.pdf
Leonard Stephen Thill
Most EPC majors develop their own, some vendors supply them and many of the design packages such as PDS, PDMS, Timberline and Puma 5 supply an add-on set of commodity codes.
They are pimarily used for requisitioning and PO placement.
I am trying to ascertain if such such database can be obtained outside of the EPC majors and design packages.
Again, thanks for responses to date.
cheers
