Pump low on head
Pump low on head
We've got a vertical turbine pump 4 stages 3 primary and 1 inducer. The pump is tested and 50 ft low in head....we've checked the wear rings, there's no slip in the impellers, we don't expect it to be hydraulics because efficiency is fine. Impeller diameter is normal.
Any suggestions????
Any suggestions????
RE: Pump low on head
furthermore, providing design condtions and tested conditions will be helpful as well.
good luck!
-pmover
Steve
Keith Cress
are you certain the impeller in the reduced head pump are identical to other similar pump?
thanks for clarifying the problem!
good luck!
-pmover
http://virtualpipeline.spaces.msn.com
Thanks for all the input!!!!!
