Importing features into a part
I am trying to import a feature into a pro/e part, but I am not sure if it can be done. I want to take computer plug and insert it into the pro/e part and have it imbeds itself into the part. Can this be done?
Thanks!
Thanks!
RE: Importing features into a part
insert -> shared data -> from file
and then browse to the location of the part you want to insert. It will appear in the model tree as an import feature amongst all of the other features.
I have used it sucessfully with an IGES file, but not tried any of the others.
Rich
as you can edit definition and then select the orientation tab and flip your references to have the plug face in the direction it's needed
