Used 161kV - 50 Hz Transformer availability
We are urgently looking for a nominal 100MVA transformer rated 11.5kV Delta / 161kV Wye. This could be two smaller unis as well and the ratio coud be close requiring a re-wind as long as the tank and core are in good condition.
thank you
RE: Used 161kV - 50 Hz Transformer availability
Try:
http://www.belyeapower.com/
David Baird
Sr Controls Designer
EET degree.
Journeyman Electrician.
