How to get the unused expressions?
Hi
   I want to get the unused expressions in the part by open api, but has no found the function, who can help me?
        thanks
RE: How to get the unused expressions?
All you have to do is go to tool==>expression=> and under listed expressions change it to unused expressions.. This will show you all unused expressions.
Hope thats what you wanted to know!
  To check in a display part the following code would help.But need to add few more checks for identifying interpart exps, geometric exps ....
Try executing this as a journal
 Imports System
Imports System.Windows.Forms
Imports System.Collections
Imports NXOpen
Imports NXOpen.Assemblies
Imports NXOpenUI
Imports NXOpen.Utilities
Imports NXOpen.UF
Public Module query
    Public UFS As UFSession = UFS.getufsession
    Public NTS As Session = NTS.getsession
    Sub Main()
        Try
            ' / Get the displayed part /
            Dim dispPart As Part = NTS.Parts.Display
            ' / Retrieve part expressions /
            Dim partExps As ExpressionCollection = dispPart.Expressions
            Dim unusedExps As New ArrayList
            Dim t_expn As Expression
            ' / Iterate through the expressions in the part /
            For Each t_expn In partExps
                If (t_expn.GetOwningFeature Is Nothing) Then
                    ' / Add the unused expression into arraylist /
                    unusedExps.Add(t_expn)
                    ' / Direct the information to window /
                    writeToWindow(t_expn.Name + " : " + t_expn.Value.ToString)
                End If
            Next
        Catch ex As Exception
            MessageBox.Show("Retrieving expression not sucessful", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        End Try
    End Sub
    Sub writeToWindow(ByVal strContent As String)
        Try
            ' / Check for the status of the listing window /
            If Not (NTS.ListingWindow.IsOpen) Then
                NTS.ListingWindow.Open()
            End If
            NTS.ListingWindow.WriteLine(strContent)
            MessageBox.Show("Unable to write to listing output device", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        End Try
    End Sub
I get two compile errors when cutting/pasting that code
Line 11: 'Module' statement must end with a matching 'End Module'
Line 33: 'GetOwningFeature' is not a member of 'NXOpen.Expression'
Justin Ackley
Designer
I has found that some expressions link with sketch and drawings,not only features. how to retrieves these expressions?
 Hi anthonyo : Kindly change the "t_expn.GetOwningFeature" to "t_expn.GetUsingFeatures", this would even include sketch and all registered features
 Hi Jackley : I am guessing that you are using NX4.0.0, if you can try my code with NX4.0.3.3. the compilation and non-reference errors may dissolve.
Hi HariharanB: I use the UF_MODL_ask_features_of_exp() to retrieves the unused exps and the UF_SKET_ask_exps_of_sketch() to retrieve the used exps in display part, also need to identifying some other exps.
