Hydrotest Pressure calculation for B31.3 1966
I need to rerate a pipe installed in 1966. Can any body send me the equstion used in B31.3 1966 for calculation of hydrostatic pressure.
Thanks in advance.
M. Waheed
RE: Hydrotest Pressure calculation for B31.3 1966
Why not tell us the details about the piping system in question?
The material:
The size:
The flange rating:
The maximum (planned) operating pressure:
Etc.
I have tried to rerate it to new code but calculated hydrostatic pressure is more than actual test pressure for the line. It means hydrotest is required to new test pressure. Perhaps Rehydrotest can be avoided if we use 1966 code. After all piping was designed to that code.
The lines are 2" to 8" in size. Flanges are 150#.Material API5l Gr.B. Pressures vary from 2 barg to 12 barg.
men5muw,
-How about temperature?
-How about design condition?
