Problem Converting Cone To Sheet Metal Part
I create a circle and extrude with draft. I shell the cone. I create a rectangle and cut-extrude so that the cone is now split. I select insert bends from the sheet metal tool bar but I am not able to select the edge where I split the cone for the fixed face or edge in the insert bends dialog box. What am I doing wrong?
RE: Problem Converting Cone To Sheet Metal Part
Sorry. I posted this to the wrong forum. Please ignore or delete.
