NPSHR for Recip Pump
I have some questions regarding NPSHR for Recip pump. I have a separator which will operate around 300 psig. I am pumping the condensate from the separator to 1500 psig via a recip pump. How about the NPSHR for the recip pump? I got the data from vendor and they are saying 12 ft is needed. I am just curious whether my 300 psig pressure at separator helps NPSH?
Thanks.
RE: NPSHR for Recip Pump
The main problem that is often missed with NPSH for a recip pump is the acceleration head which is heavily dependant on the length of the suction line.
Johnny Pellin
Thanks all of you. We just double check with Vendor and they said 9 ft NPSH shall be OK. We did some simulation, when the separator operates around 300 psig, the vapor pressure is around 1000 kPa at 30 degree C. In this case, I am wondering whether the 300 psig can make some contribution to NPSH since it is 1000 kPa higher than vapor pressure.
We are also thinking to put a mass flow meter in between separator outlet and pump suction. This mass flow meter will creat some pressure loss also which is a big concern to us. Do somebody has similar experience for this? To me, if we have 1000 kpa extra (operating pressure-reid vapor pressure, then the pressure loss across the mass flow shouldn't be a problem.
1000 kPa will take you a long way and will probably overcome accelaration losses too, but did you calculate acceleration loss?  Its a good habit to get into checking it.
http://virtualpipeline.spaces.msn.com
I will do that to see what happen.
