Part design Multi Part Body Design - Cannot Reference Other Bodies
I have a simple part with 5 bodies.  I have created a new body and would like to create a pad referencing the surface from another body which to extrude up to.
The error: "select a face belonging to the current body or part body"
I've never gotten this one before.  Is this a setting issue?
RE: Part design Multi Part Body Design - Cannot Reference Other Bodies
Up to last, up to next refer to a piece of geometry in the active body.  You can use up to plane and pick a pad face of another body.
Derek
I want to extrude between two surfaces of other bodies.  I am using "up to surface"
Your doing something that CATIA wasn't intended to do...
to expand on Derek's workaround; try extracting the surfaces from the other partbodies first, then use them with your exturded partbody.
