Rectangular Vessel
Rectangular Vessel
Rectangular Vessel
For rectangular vessel, what code should I use for tmin calculations?
RE: Rectangular Vessel
If you are in an area which normally uses ASME VIII, then you'll probably find yourself using VIII Div. 1. If your jurisdiction prefers another code, you'll use that. Where will this vessel be installed?
Thanks, jte.
I usually use SEC VIII Div.1. But which part of Div1 is for rectangular vessel? I am designing a leakbox which will be like a rectangular vessel.
MechEMain, see Apx 13.
Mike
How big?  Atmospheric or elevated pressures?  What is the product?
If it's relativly small, and free vented (no pressure) go with UL 142.  Much simpler than ASME.
Team Members
Additional Reference:
Inspection Guidelines for Pressure Vessels and Piping Volume 2: Manual and Pocket Guides MTI Publication 49.
Leonard Stephen Thill
