Screen wash Mixing pump
I am reverse engineering a screen wash system (our supplier has gone bust). I need to identify a mixing pump that is powered by the high pressure water supply, that draws in anti-freeze and mixes it with the output?
Any ideas?
Any ideas?
RE: Screen wash Mixing pump
Good luck,
Latexman
The water is supplied a 3 bar, and mixed 3:1 with anti-freeze.
The fittings are 3/8 BSP.
The water drives a double piston crank, which drives the anti-freeze pump. It is not an eductor, but like an eductor has no other power supply.
Good luck,
Latexman
It is a "Water Driven Proportioning Pump"
supplied by Shurflo
http://w
if you are interested.
Thanks for your interest.
Colin
Good luck,
Latexman
