Draft hinge
Draft hinge
Draft hinge
Greetings,
I was wondering if someone could tell me how to create a draft hinge curve on a solid based curved surface.  For instance imagine I extruded an ellipse and wished to generate a draft on the curved portion of the extruded ellipse BUT I want to have the draft hinge follow the curved surface using an arbitrary curve that I define on this surface.  A plane used to define the hinge of the draft in this case fails to meet my need.
Thank you
ThetaJC
Founder of www.engspreadsheets.com your source of no cost, professional grade spreadsheets.
RE: Draft hinge
FYI, this is for Pro E Wildfire 3.0.
ThetaJC
RE: Draft hinge
Try projecting a datum curve onto your curved surface then use this as a neutral curve for your draft.
Ray
