Rotating Part To A Certain Number of Degrees
I have a rectangular bar with a oblong
slot through the middle. In the center
of the slot I have an axis to rotate around.
How can I rotate the bar around the axis
a certain number of degrees? (like, for example 2 degrees)
instead of free dragging it, which does not good...
Thanks for any help....
RE: Rotating Part To A Certain Number of Degrees
Go to Tools/Options/Systems Option/View Rotation and set the arrow key degrees box to what ever you want.
Eddy
Dan
www.eltronresearch.com
