Advanced Gas Turbines (LDI)
I am in search of information pertaining to advanced gas turbine engines. In particular, I am interested in locating articles, web sites, companies, or anything that will give me information pertaining to lean-direct injection (LDI). This is a process that is currently being researched which will increase the pressure and temperature of a gas turbine engine while keeping the NOx within expectable limits. The only information that I currently have is from the mid-90’s. This information stemmed from research being done at NASA for High Speed Civil Transportation. Any ideas would be greatly appreciated.
Ross A. Watters
ross_a_watters@hotmail.com
RE: Advanced Gas Turbines (LDI)
Hi Ross:
I would suggest to check out the DOE web site -- http://www.energy.gov -- where you can find out information on advanced gas turbine cycles, operation and the current technology status.
Gordan
NASA still has a few doc's avail @ sti.nasa.gov which may be more current than what you have seen. Gas-turbines.com has some links which may lead to info as well. I have been cautioned about DLE not being able reach the stated claims for low nox, so i have focused on water and steam until the jury comes back in.
