viscous pore/orifice flow
I'm looking for a guideline for approximating flow velocity through a pore or orifice for a given pressure and viscosity.
eg
My pressure differential is 13 kPa
The pore/orifice size is 0.5mm
Will a fluid with a viscosity of 1000cP be able to flow through this hole?  What would be its velocity?
At what viscosity will there be no flow?
How concerned should I be about surface tension or other factors?
Thanks!
