Steel connection help
I do mostly residential so I dont detail a lot of steel connection. If you have a steel hip beam supported by a steel column 1/3 of the span. How do you support it? Do you put a steel stand off so the plates for the connections are flat? Or do you just bevel cut the column and put a plate in an angle? I am sure both ways will work. I just want to know how it is usually done.
RE: Steel connection help
Mike McCann
McCann Engineering
