Linking two views together so the one follows the other.
Hello all. In Catia V5R16, i want to link two views together so that the one follows the other when it is updated, almost like a position link for text or like views when projected off another from the word go. I also need these views to stay aligned. (It's like an overlay of one view on top of another with different data shown. What is happening now, is that when the main view is updated, it moves around on the sheet and the overlay doesn't follow. Any help???? Thanks in advance!!!
RE: Linking two views together so the one follows the other.
What kind of view is the second one?
I tried to duplicate your situation, but I wasn't able to keep the views superimposed on each other.
this is not the answer you are waiting for but it might help...
there is an option in the Standard of the drawing. In Format / Sheet / size : Generative view positioning = (part bounding box) or (part 3D axis).
if you chose the last option views should not moved once created.
if you chose the first option, views are moving with geometry change.
You might have to change / define your Drafting Standard and upgrade existing drawing to this new standard.
