Assembly model tree feature display
In Pro E 2.0 I want my assembly model tree to show features and supressed objects automatically without me having to check boxes every time.Which config file would this be?
RE: Assembly model tree feature display
Firstly get the model tree configuration how you want it, once you've done that choose settings at the top of the model tree and 'save settings file'. Now go into tools\options and set the mdl_tree_cfg_file option to point to your recently saved tree.cfg file. Don't forget to save the config.pro file. Now everytime you open up Pro, the model tree should be as you want it.
Hope this helps.
Jeff
Jeff
It's all part of life's rich tapestry!
