small bore valve info
I need some basic info on small bore welded valves.
I thought the typical end connection would be socket weld and the body would be forged. ratings types are limited. some vendors have 600 and 1500 while others may have 800 and 1680.
now lets say I need butt welded.
would the bodies be cast?
would small bore butt weld valves come in a wider range of ratings (150, 300, 600, etc)?
thanks
Mark
thanks
Mark
RE: small bore valve info
Just a point, you do realize that socket weld ends and butt weld ends are NOT the same thing!??
