linking of part family to external spread sheet.
i want to drive the value of a cell in part family from an external excel file. When both the spread sheet files are open and i make any change to the source file the value gets updated in the part family. But if the part family spread sheet is closed and i make any change in the source excel sheet then when i open the part family spread sheet it does not update. Apart from that the link between the two spread sheet gets automatically broken.
Please some one guide me.
RE: linking of part family to external spread sheet.
You can certainly save a copy of the file make external changes to it and then paste across the values when next you open the part family if that is what you wish to to.
Hope this helps
Hudson
Actually I am managing with a similar technique like what u have suggested. But it would have been of great help if the part family values could be driven without any breakage of link from external excel sheets..
Hi rk,
I guess you might have used Data->Import External Data->Import Data in Excel to achieve this. To establish the value refresh link, you should check ON "Enable Background refresh" and "Refresh Data on file open" in the properties option while setting the import data options.
For more clarity refer this link :http://w
This should help...
HariharanB
