Batch Mode
Batch Mode
Batch Mode
Is there a way to run SolidWorks in batch mode?  I want to modify the design table, SolidWorks to update the model and export a parasolid file.  Right now I have this working inside an optimization however the GUI is popping up each time taking resources and being really annoying.  Thanks for the help.
Rob Stupplebeen
RE: Batch Mode
SBaugh,
I already have a method of changing the design table in batch mode as an external Excel file.  What is TS?  Thank you for the help.
Rob
RE: Batch Mode
What kind of "optimization" are you talking about?  Have you written external code to automate SW opening? If you have a little VBA knowledge you can open SW invisibly and do what you're wanting to do.  TS is Task Scheduler.
