Subroutine - dload
Subroutine - dload
Subroutine - dload
Does anybody can check and and give me a tip about this subroutine.I wrote the subroutine which should distribute pressure over a certain surface as b - spline function.
When I started the analysis i didn't get any file like msg. odb....I think that the problem is with subroutine-maybe variable definition.
Thanks for your help in advance
in input file I used:
*Dload
Surf-1, PNU, 1.
SUBROUTINE DLOAD(F,KSTEP,KINC,TIME,NOEL,NPT,LAYER,KSPT,COORDS,
     1                 JLTYP,SNAME)
C
      INCLUDE 'ABA_PARAM.INC'
C
      DIMENSION COORDS(3)
      CHARACTER*80 SNAME
C
C     B - SPLINE FUNCTION
C
      REAL RX
      REAL RY
      REAL FX
      REAL FY
C
C
C
      RX = ABS(COORDS(1))/0.5
    IF (RX > 2) THEN
        FX = 0.0
    ELSE IF (RX >= 1.0) THEN
            FX = (1.0/6.0) * ((-1.0)*RX**3 + 6.0*RX**2 - 12.0*RX + 8.0)
    ELSE
            FX = (1.0/6.0) * ((3.0*RX**3) - (6.0*RX**2) + 4.0)
    END IF
C
C
C
    RY = ABS(COORDS(2))/0.5
    IF (RY > 2) THEN
        FY = 0.0
    ELSE IF (RY >= 1.0) THEN
            FY = (1.0/6.0) * ((-1.0)*RY**3 + 6.0*RY**2 - 12.0*RY + 8.0)
    ELSE
            FY = (1.0/6.0) * ((3.0*RY**3) - (6.0*RY**2) + 4.0)
    END IF
C
C
C
    F = FX*FY
C
      RETURN
      END
RE: Subroutine - dload
Is the subroutine compiling/linking successful ?
Did you check the .log file ?
Your formatting (spacing, indents) is wrong - FORTRAN is quite picky!!
Try:
     1 COORDS,JLTYP,SNAME)
C
C
      DIMENSION COORDS(3)
      CHARACTER*80 SNAME
C
C
      REAL RX
      REAL RY
      REAL FX
      REAL FY
C
C
C
      IF (RX > 2) THEN
        FX = 0.0
      ELSE
      END IF
C
C
C
      IF (RY > 2) THEN
        FY = 0.0
      ELSE
      END IF
C
C
C
      F = FX*FY
C
      RETURN
      END
Well, did it work for you? ;)
Yes Brep it's working. Formatting was wrong.
