bearings with no inner cone any ideal where to get
i need some bearings for my steering shaft on tractor they are like a tapered roller bearing  the outer race then go in but have no inner race they fit on a cone made on steering shaft  they are just like tapered roller bearings but without inner race does anyone know if a company makes bearings like this i think mine were made in a company from the uk
RE: bearings with no inner cone any ideal where to get
I have seen similar bearings  that used automotive wheel bearings sans cone.
I beleive the old Timken Blue book had listings for steering box bearings, as well as NDH/Hyatt or BCA. Sometimes you have to find someone with the old tech books.
Is it a ball, tapered roller or barrell roller?
Russell Giuliano
Is the inner race part of the steering shaft? That would seem to be the case, or is it pressed onto the shaft?
what brand and year of tractor?
For US made tractors of the 30s 40s and 50s much stuff is available
the bearings are tapered roller and yes the inner race is part of the steering shaft the tractor is a Long made in romania it is a 76 year model the bearing brand is urb whih is still an existing bearing supplier i think
