mule car vs. protoype
What does the terms "off tool" and "off process" mean? what is a mule car and what is its difference with protoype?
RE: mule car vs. protoype
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Off-tool means that it is a part that is made on the production dies/tools, but not neccessarily at the production rate, and it may not meet the spec. That's what you'd use at your confirmation prototype build, typically.
Off-process is not a term I've heard before but random googling indicate sthat it is parts off the production tool, /and/ using the intended production process, and line rate etc. I don't know whether they'd be in spec, or if this is what you'd use to establish capability.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
-with the final tooling
-on the prescribed machine
-by the prescribed supplier
-to the prescribed manufacturing process
-at the production processing rate
Bill
//Cheers,
For instance we routinely alter weights, CG height , and some panels, suspension geometry, spring rates, shocks, sta bars, steering racks for mules.
Cheers
Greg Locock
In my own experience, the term 'Mule' has only been applied to vehicle where the purpose of the body shell is to act as a vehicle to carry engine/transmission/suspension development actions. Hence the Mule just carries the parts.
Cutting and carving of the body to pacakge a new engine/transmission/suspension usually means that the body is not a valid tool for final body structure validation.
Bill
Most mules are for ride and handling, roadloads, and powertrain/driveline work.
This thread hasn't mentioned bucks, which are stationary mules, used for packaging and interiors and so on.
Cheers
Greg Locock
annafergusen1980, can we take it that you are involved in a vehicle development programme in a professional way and this is your first experience of them?
I see you've also asked questions about 'Engine manufacturers' and 'Product planning in GM'.
Bill
Thank you Bill for your comment on that "off-process" thing and I can see you are keeping my track from that product plannig thing which was for quite some time ago.
//Cheers,
Anna
Bill
If you combine a mule and a buck for purposes of mock-up does it produce a muck-up???
Bill
