NEiWorks vs ADINA
NEiWorks vs ADINA
Has anyone used either of these softwares? We currently use Cosmos, need to upgrade and are limted to evaluating these two only.
I need to compare and contrast both for static solid modeling that may or may not incorporate multi part assemblies with contact (the contact algorithm(s) need to be very robust), friction (various models), elastic-plastic and shape memory alloy analysis, and multiple loading scenarios in the same analysis (e.g. interference fit with > 2 parts followed by moment load or additional loading scenarios). They should also not be significanlty limited in what can be changed in the model when wanting to do a restart analysis. Either software should be able to handle improperly supported bodies (i.e. via contact damping, stiffness stabilization and/or limiting incremental displacement features) during a multi part assembly with moving contact (not bonded).
RE: NEiWorks vs ADINA
