Tandum Wiring
Tandum Wiring
Hi brothers,recently got some recommendation to make the building design to be more "environmental friendly". LEED kind of consideration. Something good but needs more learning.
Soon, i come across a power point from authorities which recommending using "TANDUM WIRING" for fluorescent light . The idea i got about "tandum wiring" is sort of low lost ballast sharing between adjacent light fittings.
Anyone used this kind of wiring method before? What is the pro and cons? Thanks for the guidance.
RE: Tandum Wiring
The downside of this is only that added care is required to make sure that all the spaces are properly coordinated with the ballasted and unballasted fixtures properly paired. As well as coordinating the tandem wiring fixture whips, etc....
Here in California there are additional requirements for controlling the "Daylit Zones", adjacent to all fenestration, which can complicate this a little bit more, but once you get used to doing it, it flows fairly smoothly.
Hope this is of some help.
EEJaime
RE: Tandum Wiring
Do you have any literature resources that can share with me in order for me to sell to management . Trying to understand more so that clear and understand the impact to every party including operation guy.
