What is the difference between Jp4 and Jp8
I need to know about JP4 and JP8 fuels.
They both are made by blending of kero with additives.
Which one is economically better?
RE: What is the difference between Jp4 and Jp8
You need MIL specifications or oil company contracts for details on JP-4 (jet propellent 4) or JP-8. JP-4 was a kerosine/gasoline blend. JP-8 is a kerosine based fuel with the high altitude additives. You may buy the Air Force specification MIL-DTL-83133E, Turbine fuels, aviation, kerosene types, NATO F-34 (JP-8), and NATO F-35, and JP-8+100. The cost is about $31 USD. I don't know where you will find details on the obsolete JP-4 specification.
typically composed of about 50-60% gasoline and 40-50% kerosene, is highly volatile, and contains hydrocarbons in the C4-C16 range. JP-4 was the primary fuel of the USAF for decades; however, it has been phased out in favor of JP-8 (see below). When specified, it can contain a full additive package including a corrosion inhibitor, anti-icing, and anti-static compounds. An optional additive is a metal deactivator.
JP-8 was developed to be less volatile and explosive than JP-4. (Commercial Jet A-1 fuel is equivalent to JP-8). In 1996, the USAF completed conversion from JP-4 to JP-8 fuel. It contains a full additive package including a corrosion inhibitor, anti-icing, and anti-static compounds. Optional additives are an anti-oxidant and a metal deactivator.
JET A1 primarily differs from JP8 in that its specification ASTM D1655 does not REQUIRE the three additives that are specified and contained in JP8; namely, the Corrosion Inhibitor/Lubricity Enhancer, the Fuel System Icing Inhibitor, and the Static Dissipater Additive.
download this for more JP8 info,
http
http://virtualpipeline.spaces.msn.com
JP8 ST, 1995.
I copied sections of an article on the inernet:
That's why I open my cigarette pack at the bottom.
